Subject: Re: Regner Max including upgrade info Fri Feb 17, 2012 8:12 pm
Looks pretty neat, but the instructions seem to have gaps in them. The boiler/engine kit lists for $100 and the assembled version is $160. The assembled version comes with a relief valve; the kit doesn't. They are made as power for model steamboats & are fired with Sterno.
Unfortunately, both are listed as "Out of Stock". You can however download the instructions from the manufacturer's website.
Subject: Re: Regner Max including upgrade info Fri Feb 17, 2012 9:42 pm
That's very depressing (and envious) when you see things like that.
People who can make their own boilers and fittings and put it all together.
Subject: Re: Regner Max including upgrade info Fri Feb 17, 2012 10:27 pm
Yes, Harry is a good steam guy, I have bought a few items (1/8" steam line and oil) from him and he mentioned these boilers.
He is also making a double-sized LBSC Tich for himself. You can see some pictures at that page.
The one interesting moment was when I showed him my IP Engineering "Jane" boiler. He asked what it cost and when I told him (around $220 due to the terrible exchange rate at the time) he told me it was a bargain as he could not come close to making one at that price.
So one has to wonder what his coal BAGRS boilers would cost!
_________________ Garrett
Carl Hibbs Admin
Subject: Re: Regner Max including upgrade info Sun Feb 19, 2012 3:55 pm
Some more Max progress....
Started with a new aluminium floor and buffer beams
Then I decided to make a small condenser.
The exhaust steam pipe is now routed through the chimney.
A simple new 'body' was fabricated from brass with an alluminium roof. This gives it quite a bit more weight with the floor.
This the old body longer in comparison which was inequal over the chassis wheelbase.
I am waiting for some add-on parts from Regner before progressing any further.
Subject: Re: Regner Max including upgrade info Sun Feb 19, 2012 4:10 pm
EXCELLENT!!!
Smart idea to route the exhaust through the chimney.
_________________ Paul
Subject: Re: Regner Max including upgrade info Sun Feb 19, 2012 4:14 pm
Great work! You have really improved the model.
Yes, the lack of blanace/inequal spacing of the model has bothered me. You have addressed this quite well!
I assume you fabricated the condenser? If so, looks good.
I am guessing you used a diamter of copper plumbing tube and then 1/8" or 3.5mm line (I re-plumbed much of a Citroen GS years ago with 1/8" line, it was close enough) for the feed and exhaust.
It also apperars that you then step down to a thinner tube up the chimney? If so, I wonder if there will be any impact of the restriction in terms of backpressure, as on some ozzy models (such as the Mamod) this helps keep speed down.
Carl Hibbs Admin
Subject: Re: Regner Max including upgrade info Sun Feb 19, 2012 4:30 pm
I used 3mm copper pipe (we're all metric here.... ) This was indeed stepped down to 2.5mm brass tube to negotiate the flue tubes in the boiler.
The condenser is just a home made sump from a piece of 16mm copper pipe.
I haven't steam it up yet. That will have to wait until next weekend now.
Subject: Re: Regner Max including upgrade info Sun Feb 19, 2012 4:33 pm
I noticed the drain bung also, good work Carl!
Carl Hibbs Admin
Subject: Re: Regner Max including upgrade info Sun Feb 19, 2012 4:41 pm
Thanks Garrett,
With it open at the back you can remove the fuel tray more easily now.
The problem I have at the moment is the locomotive is no of use for the Momi module as it needs to have a means of reverse and be radio controlled. So that is the next step and a challenge to fit the rc gear out of sight.
Subject: Re: Regner Max including upgrade info Mon Feb 20, 2012 6:34 pm
Apart from a remote controlled finger, how would one remotely change the direction on this loco?
Maybe you should add some plumbing from the keg to Max and convert it to alcohol fired.
_________________ Bill Wray
"It is one of the happiest characteristics of this glorious country that official utterances are invariably regarded as unanswerable." -Sir Joseph Porter, First Lord of the Admiralty (HMS Pinafore)
Subject: Re: Regner Max including upgrade info Mon Feb 20, 2012 6:52 pm
I am guessing the model is not a "self starter" being a single cylinder ozmotor...
Carl Hibbs Admin
Subject: Re: Regner Max including upgrade info Mon Feb 20, 2012 9:14 pm
By reversing the steam connections between inlet and exhaust.
Thats why Regner sell a turret valve (Umsteuerventil) for this locomotive, part number 40548. Connect that to a servo and away you go ........or come, hopefully.
Carl Hibbs Admin
Subject: Re: Regner Max including upgrade info Mon Feb 27, 2012 7:00 pm
Well it came to pass today and into steam it went.
Here's the film courtesy of YouTube's new video editor:
Some pluses and minuses.
It is controllable at slow speeds but is inclined to stall suddenly if the pressure drops and won't self start...yet!
The fuel I was using was more fluid than gel/past like Sterno but cheaper and the flames were a bit wild in the open wind. I think a ventilated shroud around the base maybe useful perhaps some flame arresting mesh as I can see problems with fire insurance claims at exhibitions....
The condenser isn't that essential as there wasn't a great deal of water and oil thrown out but it works anyway and the steam looks better coming out the chimney.
I'm still waiting for more parts from Regner to make some further modifications notably reversing.
Subject: Re: Regner Max including upgrade info Mon Feb 27, 2012 7:19 pm
I noticed the flames on your videos when you posted them on Youtube this afternoon. Spectacular but I don't think the organisation of an event will be very glad with that indeed... The rest looks very promising!
Carl Hibbs Admin
Subject: Re: Regner Max including upgrade info Sun Mar 04, 2012 4:07 pm
Well...Regner service when ordering parts is very good if you use their slightly quirky online ordering system. So the parts came to do some more upgrading. Water filler and turret valve to allow reversing plus some odd parts to cobble together a water level indicator.
I had to embark on some creative plumbing for the sight glass as the normal length Regner one for locomotives is too long and I thought it useless to make it smaller to fit the vertical holes. The top is now connected to the hole round the other side of the boiler and has a tee for the filler.
Small turret valve now fitted which really needs lapping in to make a better seal.
I also made a simple mesh fire guard to stop the wild flames. It seems to work ok indoors. I have some film which I'll post later.
Subject: Re: Regner Max including upgrade info Sun Mar 04, 2012 6:12 pm
Excellent craftmanship Carl!
Carl Hibbs Admin
Subject: Re: Regner Max including upgrade info Sun Mar 04, 2012 7:50 pm
Just mini plumbing Paul and everything is available from Regner.
Here's some test film. I didn't run outside as the windy wet weather here is atrocious at the moment.
Subject: Re: Regner Max including upgrade info Mon Mar 05, 2012 11:25 pm
Looking good, Carl. Nice plumbing work for a telephone repairman.
I'm curious - if you use the turret valve to control the speed, will that cause premature wear?
Carl Hibbs Admin
Subject: Re: Regner Max including upgrade info Tue Mar 06, 2012 9:06 am
Hey... a digital telephone repair man.
Why do you think that? I'm curious too now. What parts could wear prematurely?
I have a Regner Emma that only has one channel radio control on the turret valve. I just keep the manual regulator open to let steam in and use the turret valve for speed and reverse but there isn't a great deal of fine control although you can juggle with opening and closing, rather like slipping the clutch.
I've never really considered any wear aspects.
Subject: Re: Regner Max including upgrade info Tue Mar 06, 2012 2:39 pm
Two wear mechanisms come to mind. First, you will likely be manipulating the position more frequently which will increase the face to face (or seat to stem) wear. Second. throttling steam across a valve causes seat wear unless the valve was designed for this service. A brass valve is going to be soft seated, so I suspect there will be some increase in wear -- the question is how much?? Only time will tell, but my guess is with the relatively low pressure of the steam, the wear will not be a huge problem. Your experience with Emma would seem to bear this out.
BTW, is a digital telephone repairman one who works with his fingers? I know I had a digital examination once - it wasn't a pleasant experience.
Subject: Re: Regner Max including upgrade info Mon May 28, 2012 2:15 am
I finally got my hands on dads two year old (and still not fired!) Regner Max today. Even with the purchase of the Bix gas burner, he still thinks he will "run it one day".
I have earned a new respect for the construction of the model, including the ozmotor.
I still wonder if I should purchase one, but I somehow think I will end up with dad's in the near future.
