 Auvergne Mining Project
Go to page : Previous  1, 2, 3
PostSubject: Re: Auvergne Mining Project   Mon Feb 25, 2013 8:31 am
Oh alright I'll come clean, I'm teasing you, I know you're searching for the perfect louvres Basketball
The aluminium (not zinc) bonnet is actually a heat sink component stripped out of an old French car radio. I've a box full of useful aluminium heat sink sections, but the minute I laid eyes on these I knew what I was going to use them for!
On a serious note, I did see an article many years back (in Railway Modeller I think) on how to make louvres and I plan to have a go for my live diesel body. Basically the process invoved making a negative mould in wood for a single louvre, making the vertical slit with a dremel and laying the THIN brass sheet over the mould and punching the indent with a chisel shaped tool which matches the mould of course. I've not tried it myself but reckon having a thin sheet would be key!
study
PostSubject: Re: Auvergne Mining Project   Mon Feb 25, 2013 8:42 am
Ah so the louvres were already punched then....... pirat
But that itself is a very good idea...maybe I'll have a look at old computer or other small electrical equipment casings..... Idea
The female die and male punch I've seen explained in slightly different forms using a chisel as well.
I've had some minor success with this but it is tedious and needs care.
PostSubject: Re: Auvergne Mining Project   Mon Feb 25, 2013 8:05 pm
study
Having had to use a crowbar over the weekend in a tight corner on the K&NWLR, I realise that I might have another use for it. Which make of car was it where you found the radio? Although explaining that I used it for railway modelling if stopped by the gendarmes might only lead to (more) trouble.
http://www.youtube.com/user/KandNWLR?feature=mhee
PostSubject: Re: Auvergne Mining Project   Sat Mar 02, 2013 2:02 pm
A lick of paint and a few Preiser figures and the module is starting to come to life...
Unfortunately my rockwork looks a bit like an infants' school papermache class. I just hope the patrons of Ferrovi'art will see it as it is - a backdrop for a bit of animation!
PostSubject: Re: Auvergne Mining Project   Sat Mar 02, 2013 4:58 pm
félicitations Exclamation Exclamation Exclamation Exclamation Exclamation Exclamation Exclamation Exclamation
PostSubject: Re: Auvergne Mining Project   Sat Mar 02, 2013 6:44 pm
Apropos rockwork. One of the things that you can do - if you want to do all your plastering in one go (and you´re modelling smaller modules) - is to place the area you are "rocking" on a flat surface, with the cliff face lying on your workbench, so gravity doesn´t affect your work. And if you return a couple of hours later you can have the fun of inscribing the "rock" with the geological patterns that fit your subject.
This being said, the K&NWLR has just spent two hours demolishing a failed platform outside the new warehouse and building a new one with a piece of wood and some industrial-strength polyfilla. The now sagging cliffface, as yet unseen on this forum, will be covered in plants ....
PostSubject: Re: Auvergne Mining Project   Sun Mar 03, 2013 11:22 am
Brilliant Brian, looking forward to seeing this in a few weeks time. Very Happy
PostSubject: Re: Auvergne Mining Project   Sun Mar 03, 2013 4:33 pm
I've just put the Mine and Cognac modules next to each other and will spend the next few sessions getting them aligned and laying the surface tracks... pics to follow
PostSubject: Re: Auvergne Mining Project   Mon Mar 04, 2013 9:13 pm
Finally linked up the two modules and started positioning the surface rails...
PostSubject: Re: Auvergne Mining Project   Mon Mar 04, 2013 9:16 pm
félicitations Brian Exclamation Exclamation
PostSubject: Re: Auvergne Mining Project   Wed Mar 13, 2013 2:20 pm
Some changes in the hidden mine section...
PostSubject: Re: Auvergne Mining Project   Wed Mar 13, 2013 3:50 pm
Question Some changes in the hidden mine section... Question
PostSubject: Re: Auvergne Mining Project   Wed Mar 13, 2013 6:44 pm
This is looking very good! But the video needs kicking .... "pas disponible"
PostSubject: Re: Auvergne Mining Project   Wed Mar 13, 2013 10:42 pm
I think it's OK now? A bit slow uploading to Youtube!
PostSubject: Re: Auvergne Mining Project   Wed Mar 13, 2013 10:48 pm
Arrow
PostSubject: Re: Auvergne Mining Project   Thu Mar 14, 2013 7:30 am
Excellent!
PostSubject: Re: Auvergne Mining Project   Fri May 10, 2013 10:11 am
Brian, how about one of these
http://belfieldhall.co.uk/belfield/ngr/walkingman_01.html
Magic.
Page 3 of 3Go to page : Previous  1, 2, 3
